Disables the generation of ICMP redirect messages on one or all VLANs.
| name | Specifies a VLAN name. |
Enabled.
Disables the generation of ICMP redirects (type 5) to hosts who direct routed traffic to the switch where the switch detects that there is another router in the same subnet with a better route to the destination.
The following example disables ICMP redirects from VLAN "accounting":
disable icmp redirects vlan accounting
